1 - 4 of 4 Posts
I'm running a 552" BBF with a Kaase wet sump pump. Anyone else running one of these remote clearview filters with -12 feed/return line? What was the affect on oil pressure, if any?
The small filter will be the restriction. Unless you use one of the racing filters and I don't like using the large micron filters.
A block mounted filter on a 557 was down about 10lbs on dyno compared to my oberg and large 1 1/16 filter I have on the dyno.
We didn't notice any real or noticable change on a BBc 509 incher with Mellings HV pump. We didn't use the Clearview WITH the spin on though. I think we should have used that one. That's a nice 2 stage filter setup. Larger 50/60 Micon in the clearview and small 10 micron in the spin on.
I got the clear view with the chevy spin on so I could use the larger 13/16” threads. I have always run the Jomar oil filters. Glad to hear no noticeable pressure drop though.
1 - 4 of 4 Posts
