1 - 13 of 13 Posts
hey guys I about to assembly my short it is a 8.2 deck 347 and. I can't find any clearances for the short block any info would be greatly apperiated
What clearances are you looking for? Bearing clearance try and shoot for .0025 on mains and rods.
what clearances do you need to know..
as like
how much clearance from the headers to the K member and oil pan...........?
or
how much clearance from the back of block to the firewall of chassis...???
or
how and what are oil clearances of crank to rod bearing ETC....?
you have to explain what you are doing....
as like
or
or
Why you gotta be such an ass???? :smt102
....LOOOOOOONG STARE...
and so,..... please give the answers to an un asked question....
and so you can answer a question,....... without knowing what the question is......??
Again, see post 5!
And maybe post 2 also, as he asked the same question, without the attitude you always give.
Assuming you weren't being an ass (and I am wrongly accusing you of such), what would the header to K frame clearance have to do with the short block clearances????
so,
do we have to list all of the possible questions and the answers too.. as like
oil pickup to pan clearance
pan to side windage tray clearance
clearance of crank to oil seal
clearance of cam drive chain to the face of block
or underside of the front cover
or how much clearance the rocker is to the valve tip
or how much clearance from piston to valve
or WHAT...
it must be a silly question.
but we all really do not know what the question is....................do we....
there must be an EASY ANSWER out there....!!!!!!!!!
...so what is the clearance question....???
... O.P. .....
o.k.
so what type of measuring tools do you have...?
what type of measuring instruments do you have ...??
have you done this before or is this your first engine buildup assembly....?
1 - 13 of 13 Posts
