1 - 5 of 5 Posts
im getting ready to fire up my car and was just checking over everything before startup. couple of weird things going on
tps is only reading a max of 40% when tb is wide open
air temp and coolant temp are reading 33* when its 70* ambient.
anyone e have any ideas. would like to start it up this weekend.
thanks
devin
EFI/N2O JUNKIE
Check your +5 volt reference and grounds.
Easiest way is to unplug the TPS sensor and check for 5 volts to the block and to the correct pin in the connector. Do the same thing on your MAP sensor. If the +5 volts is being pulled-down from something it will screw-up everything! A bad ground will also wreak havoc.
thanks I will be pulling the dash tomorrow and check all my grounds and +5 volts at all pins and ecu
1 - 5 of 5 Posts
