1 - 2 of 2 Posts
Drive Shaft Problems? (McDonough)
Date: 2011-02-09, 5:53PM EST
Reply to: [email protected] [Errors when replying to ads?]
To: [email protected]
Thank you so much. I ended up taking the truck to Driveline in Stockbridge. The guy pulled the shaft to check it for any twist and examined the U joints and mounts for $50.
Everything was OK. He said that he and a friend had the same problems that were resolved in trucks like mine by replacing all of the ignition coils, so I bought 8 new coils
at Summit in McDonough. I found a guy in McDonough that said he would replace the plugs with double titanium and install the coils for about $150. If I still have problems after that,
I guess that it could be the rubber transmission mount, or worse, a transmission problem. My transmission fluid has not turned orange and looks OK, though.
One of these days I will learn how to chuck the wheels and try to shake the Universal joint myself, but I cannot complain about $50, and I would do it all again.
Thanks again!
  • it's NOT ok to contact this poster with services or other commercial interests
1 - 2 of 2 Posts
