1 - 3 of 3 Posts
My beater is a 1993 Plymouth Grand Voyager. There's a recall on the ABS pump, which seems to be slowly dying; do I just take it to a dealer and have them replace it? Does it matter that it has more than 100k miles? Will I be charged for labor?
Drag Week Survivor
write your vin number down and call the dealer, they will tell you if the recall is still open. Jeep cherokees had a similar problem and pretty much once it's a recall it's always a recall. So if they perform it once, then the truck has the same symptoms then need to do it again. your milage should not be a problem, and you should not have to pay anything, but your vehicle must be or have been covered under the recall, the VIN will determine that.
Cool, thanks.
1 - 3 of 3 Posts
