1 - 8 of 8 Posts
I'm a mod motor guy who finally had it with computers and sensors. I'm building a 438 sbf to drop in my '00 Mustang. Please give some suggestions for the carb (and intake).
Will be 95% race. I had a 9s/140s mod motor. Want at least that with the sbf.
Have: Dart Iron Eagle big bore, AFR 225 heads, 13.2:1 forged rotating assembly. What carb? What intake? Thanks.
pig hunter
stock holly hp 1050 and learn to tune will get you as far as any so called custom carbs out there.... if you have to have a custom call aed, cubic, book, quickfuels....
The HP vs a Dominator? Advantage or disadvantage in my build?
pig hunter
that is a 4500.. i don't use a 4150 on anything but a lawn mower lol... 4150 are fine.. i use a 4500 in most stuff 550+ even down to 450-500hp if it has a lot of gear and loose convertor.. weight doesn't mean dick to me unless it's a stick car. the convertor doesn't let the engine bog or be lazy when it's reving to 5000+ of the hit... the carb see's enough signal also.
that is a 4500.. i don't use a 4150 on anything but a lawn mower lol... 4150 are fine.. i use a 4500 in most stuff....
Alright. 4500 is what I thought you meant. Good.
Intake manifold? Any other carb opinions? I've been thinking 4500 but wanted to ask around.
pig hunter
there better ford guy then me here. start a intake thread for this build and you well get your answer.
Discussion Starter #8
Thanks.
1 - 8 of 8 Posts
