I've got an ABS light on and the codes reads for a front wheel speed sensor.
Well, I got one from rockauto put that bad boy in and boom... Still the same light. So I bite the bullet and buy one straight from the dealership. Boom, same problem!
Could the exciter ring somehow got messed up? All the connections look good. Before I switched to the OEM part the truck was hooked up to a motis and the front left wasn't reading MPH. So I thought it might be a depth thing with the aftermarket wheel speed sensor. I haven't got it back on the motis to see if the OEM one is doing the same thing. All I know is the ABS light is still glowing away..
What else should I be looking at if anything?
