1 - 12 of 12 Posts
What is the advantage of making a Ford 351w run a Chevy firing order. The motor is 30 over 11-1 compression N351 heads this will be in a dirt race car.
Long Live The King
Which firing order ?
Most people would leave the Ford the way it is...
Discussion Starter #7
Change how ford numbers their cylinders then compare firing orders again........
[/QUOTE
It was a custom ground cam from Jones cam.
No. I think you are mistaken
We only use the F351w firing order on SB Fords, unless the rules call for the old F302 firing order.
The F351w firing order is the same as the LS(43/72 Swap) firing order, after you renumber the cylinders.
Discussion Starter #10
Well looks like the engine builder put the wrong firing order on the intake put the 351 firing order on and now running. Like it should thanks guys.
Exactly. The Chevy firing order is actually the Ford Flathead firing order. 15486372.
Depends on exactly which Chevy V8 you are talking about.... it isn't if you are talking traditional Chevy SBC and BBC stock firing order, it has to be 4/7 swap firing order to be the same as Flathead Ford
Only the LS engine stock firing order matches Flathead Ford.
1 - 12 of 12 Posts
