1 - 3 of 3 Posts
We ran a big chief chevy with a good roots blower and made around 2400hp at 9000rpm and 46 psi. We knew it was getting to the limits of the combo so we picked up a D rotor psi screw. The plan was to run about the same boost{92%od} and pickup some power without twisting it harder.The limit of the engine is the valetrain,as it will destruct at high rpm or cylinder pressure.Especially the exhaust side.
We're considering a new cam to help these issues so we had the heads flowed and they are down about 50 cfm on the intake. 466. A good port can go 525.
The question is...should we work the heads over when we have cylinder pressure and rpm roadblocks anyway.Does a good flowing head make better power with less cylinder pressure? We know the D rotor can force the air through but we're to the point that we need to finesse it or both heads will be doorstops.
Thanks for any ideas,
Mike
could this down 50 be the bench or test method? fix the port and try a new cam. all of the above. 2 cents here.
wheres the static compression? 18 degree chiefs?
I'd stick that D rotor on there about 120 over, it only needs 8500.
Sounds like a decent motor if it made 2400 with the roots. Will need major fuel system changes though
1 - 3 of 3 Posts
