1 - 20 of 178 Posts
A Fine Example For Others
Here's the combo:
1. 446 Big Block Mopar 30 over
2. Sixpack Rods and pistons
3. 9.7.1 compression
4. Mopar purple cam 509 292/292
5. Edelbrock aluminum heads
6. 1.5 ductile rockets
7. Street Dominator single plane intake.
8. 2" headers, 3" collectors
9. 1050 annular carb w/ 1" spacer
10. High volume oil pump with windage tray.
11. MSD digital 6AL ignition, MSD Blaster SS coil, MSD distributor.
12. Distributor locked out, everything in at 2500rmps.
13. 3,000 stall convertor.
Take a guess for HP at the crank, and total torque
Explain 1" spacer please. One big opening or 4 holes ?
What version eddy heads ? Ported? Bigger valves? Seat work? Cam degreed in? Cam size? Headers? Primary size? Collector size? Which plus being used?
Very ill informed here.
You pulled engine from car?
And why the fuck 9.7c.r. ?
1 - 20 of 178 Posts
