1 - 10 of 10 Posts
Switched from a 1.76 to 1.80 and now car is violent on hit, went from consistant 1.17~1.19 now wont get out own way b4 blowing tires off. Would tighting convertor help calm it down
going to the 1.80 from the 1.76 isn't going to make that drastic a change,, something else is DIFFERENT,,,, didd you change the converter????????
Is it possible that the new gearset has a different spline length and your driveshaft doesn't have enough in and out clearance? If it gets bound , the rear suspension won't work properly.
Hutch
Discussion Starter #7
The new gearset seemed physically shorter to where old ones stuck out tail shaft and new ones barely come to end of tailshaft
Discussion Starter #10
BTE, 1.80's. ill get it jacked up and see how much play I have, im gonna pull convertor and have it checked out there was some shrapnel in the case from where the ole 1.76s expired
1 - 10 of 10 Posts
