1 - 6 of 6 Posts
Is it possible change the front yoke on my driveshaft and re-use it? I currently have an aluminum unit from Ford Motorsport.
Thanks,
Yes. Just make sure of the length. I'm not sure if any changes are require to the length of the driveshaft itself.
If your transmission is equipped with a rollerized tailhousing instead of having a bushing, you'll need to use a hardened yoke.
g
All motor wannabe
do you have motor plates? is the motor moved back at all? im doing a c4 to glide change currently i have a frpp shaft as well but im having team z move the drivetrain back
1 - 6 of 6 Posts
