had a 5500 converter in my truck, th350 basically stock, changed to a 4800-5000 converter and installed a tci manual valve body. With the 5500 converter, truck pulled the wheels 6" for about 10' , now, it pulls the front end up no wheels off the ground, then spins!
S10 with home made style caltracs 1/2 turn preload. Bars in top holes, but bars are on slight angle down.
Track was mint, hold down some 8 second cars!
I changed stalls because I figured the other was too big, didn't really here it shift into third.
Do I switch back to the other stall?
It was the only thing changed on the truck, except valve body, but maybe with the new valve body, and old converter I will get a better 2-3 shift!
