1 - 2 of 2 Posts
Hi guys I am doing the change from internal oil pump wet sump setup to a dry sump Peterson.
First thing is can I run the same sump which is below and below the first pic its the one on the left side and if I can run that pan what changes will I need to do to work like a purpose built dry sump any info will be great?
also we are doing some changes to my sump now as you can see the extra ears on the side still need to do the other side and while we are doing that I hope you guys can suggest ideas to help my new setup...
PS its a 4 Stage dry sump Peterson!
You can check out my engine buildup here http://www.facebook.com/album.php?id=1840290427&aid=222
I have had a dry sump chevy motor for 7 years .my first queston is why does the pan have a front sump ?
and a kick out on the pass side rear?
is it a ford motor ?
is it a circle track car
the pan set up is just part of the whole system. I think it would be cheaper to buy a pan already set up and built from a company. if you do this wrong it could cost you a motor .
I could not see the face book page cause it required a password
1 - 2 of 2 Posts
