I’m curious as to what gains can be seen when going from 11.5 to 13.5:1 compression? What are your personal experiences? Just curious what other have experienced with similar setups.
408 SBC
Vic Jr Intake
750 CFM BG Mighty Demon (race gas)
AFR 220 heads (2.10 I/1.6 E valves)
Solid Roller cam, .682/.687 lift, 261/267 dur. w/1.6 rocker arm 110 LSA
3300 lb Camaro
Plan is to purchase domed piston and mill head to 62 cc chamber to achieve the compression increase. I’m guessing the carb will need to be upgraded as well but that is what I’m running at the moment prior to change.
Brian
408 SBC
Vic Jr Intake
3300 lb Camaro
Brian
