1 - 3 of 3 Posts
What do you guys think about having the hot side coated and then wrapping it with DEI Titanium wrap? I thinking on doing the polished ceramic coating on the cold side and leaving it shiny to match the valve covers and billet elbow, but was leaning towards doing a high temp ceramic coating on the headers and down pipes, along with wrapping it just to keep heat to an absolute minimum... Probably going to ceramic coat the whole exhaust as well for that reason.. Thoughts?
IMO, I would only use wrap if absolutely necessary as the wrap will retain moisture. In my case, I coated my headers as well as a section of downpipe that's in the engine bay. So far, that's worked well to keep the heat down. However, as my downpipe curves downward and exits the engine bay towards the rear, there's a section that comes pretty close to the tranny. I wrapped only that section of downpipe in order to minimize heat transfer to the tranny.
  • Like
Reactions: Growler
1 - 3 of 3 Posts
