1 - 4 of 4 Posts
I have a backhalfed '70 Chevy Nova I picked up a while ago. I bought the car with no rear end and plan to put in a ford 9 inch. I do however have a motor plate in the car and it is centered in the frame rails. Would this mean the pinion for the rear end would also be centered in the car??
59603
Moderator
A centered pinion is the normal location for cars constructed with chassis completely built. Some times a door car with a orgional drove shaft tunnel requires a offset pinion for clearance issues.
The reason some factory orgional cars have a offset pinion is it lets the rear end have equal length axles.
1 - 4 of 4 Posts
