1 - 8 of 8 Posts
Tire Waster
What are you guys doing about center caps for the Aluma Star 2.0 wheels? The fronts look crappy on my Camaro without a cap. I tried a Weld Draglite cap but it seems too thick unless I machine a groove in the backside of the wheel.
Tire Waster
Thanks! I am not sure the 2.2 will clear my front hubs (stock disc brake rotors 73 Camaro).
Also, on the Aluma Star 2.0s do I run a small thin washer or the fat concave washer from my Weld Wheel Draglites? The thick washer does not seem to fit the hole well.
Probably bushoging
Check your PM
1 - 8 of 8 Posts
