1 - 4 of 4 Posts
Has anyone used water/meth. injection on a 3126 cat in a toter-home , if so does it help the power output. My rig only has 300 hp and hills kill it with my stacker trailer.
On the flow bench
Usually when u notice the air to water intercooled diesel engines going really good... The cooler is generally leaking water internally :p
The water cleans all the carbon out of cylinder as well.
So, Yes it will help to spray some water
Richer diesel , like more rack travel or max fuel settings makes more boost
Opposite to gas / methanol engine;)
Only worked on 3176 engines in this cat family but...
These engines have little bw turbos
Maybe a custom turbo will help here too, but you will need a smart guy to get it right.
1 - 4 of 4 Posts
