1 - 1 of 1 Posts
Anyone running spacers on top of your plates? I removed a 1/2 inch wood spacer and am now running a 3/4 thick NX plate, and now after I get car to temp and let it sit 10-15 min it starts hard, long crank I think the gas is boiling, never had this problem when I was only running 1/2 wood spacer. If I turn off pump and run carb dry I can restart with no problem cycle pump to fill carb hit key and its on! Thanks the help is always good. ;)
1 - 1 of 1 Posts
