1 - 4 of 4 Posts
say you have a 302 v8 ford which has a bore of 4inch and a 3 inch stroke, with normal mild cam and compression in it, that 302 has a ci of 37.50 per cylinder ..and for compasion reason the carb is a 650 cfm, now say you have a motor that is 300 ci, nearly the ci , but is only 6 cylinder aka ford 4.9 liter straight 6 with a bore of 4 inch and stoke of 3.98 which gives you a ci per cylinder of 50 ci, would the same carb work or would it require a bigger carb if the said six cylinder has same compression , rpm etc..
The cylinders my be a different size, but with the V8 the cylinders fire every 90 deg, were the 6 cyl fires every 120 deg. Most likely they would use the same carb, as the v8 would have more overlap between 2 cylinders on the intake stroke for a longer duration then the 6cyl.
Hope, that make sense
Carburetors specifically designed for v6 engines are rated differently. Instead of using the standard 1.5 inch preessure drop used to rate v8 carburetors, they use a 3 inch pressure drop. For the reason stated above.......less (but stronger) intake pulses. Meaning that the v6 will create less "pull" on the carb. This mostly applies to the 2 barrel carbs. Which is why the Holley 500 cfm is essentially the front half of a 750. Conventional math says it should be a 375, but suck harder on it (3 inch pressure drop) and it flows 500 cfm. It's all relevant to the engine, of course. Put your 650 on a prostock and zing it up.......is it flowing 650? No. Probably more like 1200. Something to keep in mind when spec'cing a carb for your 6 cylinder.
its not a v6..its a 306 ci straight 6
1 - 4 of 4 Posts
