1 - 4 of 4 Posts
First of all,i have my engine 580 bbc 1300 cab at idle at 1400,when i put it in gear,it idles at 900 have to keep a little pedel on it so it wont cut off,when i go on the trans brake [3200] testing on the jack stands,it puffs alittle black smoke out the pipes,and if i let of the gas from wide open to idle fast it will cut off,but if i come off it slow it wont but it seems to be loaded up,any idea what mybe my issue would be.
larger air bleed will fix that
X2 larger airbleed. does it puff black smoke when you just hit the throttle? If so, could need a squirter adjustment...
1 - 4 of 4 Posts
