2921 - 2930 of 2930 Posts
Dove Alum. Hi-Riser heads and matching intake with two 750 hp bodied carbs.
46290
Same with two custom 1000 cfm? carbs.
46293
On the dyno with the 750's mounted sideways, 750hp bodies, 4412 primary blocks, jetable secondary jet plate, no PV's, 50cc primary pumps, no secondary pumps, 750 dp base plates.
46416
And with the custom carbs, these are about 1/2 the weight of the Holleys.
46444
https://drive.google.com/open?id=1XpgENXcQnWqd4w7aID-bH0dHS4lKm_up
https://drive.google.com/open?id=18d0QH_Y0OWwnk9Ci2bIRJ9GBLoqrash6
https://drive.google.com/open?id=137N7HFXYr_pbnMS_mCdeUyIgpX3NwoXJ
Linked them from my drive, not sure how to do pics yet on the new format and I don't have them saved elsewhere.
Same intake, basically before and after, lol. Took 3.5" out of the runner and added back 2.5" of plenum. Picked up quite a bit peak and even more average power; 30+ on both. Was already ported before I cut it up, so that part didn't change, also had 1/2" spacer between manifold and carb plate when dyno'd before cutting. 600ci simply didn't want that much runner or that little plenum. Original version had smoke swirl UP from the venturis at 6k-6200 on the dyno....:oops:
Not nearly as fancy as some, but all home grown. Just went 4.711 @ 152 on a 36 fogger in a 2850# 2x3 a-arm/ladder bar car on 10.5's at Snowbirds a couple weekends ago, so we're pretty happy with it especially for how far off the tune still is.
I had to drag the picture into post.
46296
46297
46298
A Senior Member
My injected deal i built. Plenum is 440 cuin same as motor.
48980
A Senior Member
Thanks Mark.
I wanted it to fit under our 5" cowl hood. I love the injection, stupid simple.
A Senior Member
Good luck with your test and tune, looking forward to your results.
