I asked in another thread yesterday about my timing, and I really didn't want to keep asking questions in another person's thread so I decided to just post up the screenshot I have of my timing table from HPT to see what you guys think I should do to get this thing to 60' better and get to the 330' quicker. I trap 112 on the regular with 12-15psi at mid 11's afr.
Set-up is a stock block, stock bore, stock stroke 10:1 cr 346 c.i. LS1. Stock 853 heads, comp 918's, chromoly pushrods, Thunder Racing 227/224 114lsa Reverse Grind cam, LS6 intake, stock tb, twin walboro 255's, 60# mototron injectors, 4l80e, 3800 fti stall, and 3.55 gears on a 275/50/15 hoosier drag radial.
I know I've rung every bit of 60' and 330' out of this thing the way it sits. I've tried launching off the stall's highest stall speed with no two step, I've tried giving it a good 500-800rpm flash by launching at 3000-3200rpm and it just went slower to the 60'. In my videos, every single time the back tire crosses the 60' beam the car wakes up and just rockets to life. I'm guessing its the timing and just not being enough power soon enough to move my 3900# pig off the line the way I want it too. I had been trying to conserve the stock bottom end all season, but the season is over at the end of november and I'm putting a new motor in this winter and/or forging the current one.
Here is the timing table from hpt, any helpful advice would be greatly appreciated.
