1 - 10 of 10 Posts
I have a slow 2nd gen back half Camaro. Car started pulling left and I noticed when looking from the rear it is crabbing, it looks like a NASCAR coming down the front stretch from behind. It has leaf springs ,ladder bars and a floater. Its all old school stuff. I climbed under car at the track and nothing seems bent or loose and the bushings in the leaf springs look fine. At the end of last season I noticed the car pulling left during a warm up ride in the pits but I figured the front tire got caught in a seam in the asphalt.
On the same day it pulled left on the track but I thought I was just out of the groove. Putting the car on the lift at work sometime next week, anything I should be looking for? Thanks
Cracks in the frame that open up under stress? Bushings in the leaf springs all worn to shit?
Possible broken leaf spring through center bolt.
somehow the rear end moved on the center bolt. The locator hole in the floater is bigger than the center bolt/pin on the spring. No idea how it moved everything was tight, bushings in leaf springs are good. The passenger side of rear end moved back. Car tracks good now.
Dang...forgot about that problem! Glad you found it.
FYI - the spring pads on the rear can get pounded and the u-bolts then get loose. That causes the rear to move around. I would double check the spring pads
Is there anyway to make a bushing that could tighten up the hole size on the pad vs the bolt, so even if it were to slip, its got no place to move to?
Discussion Starter #9
That's a good idea, I am sure that could be done with some trial and error cause I do not think the center bolt is is in the center of the hole (apx 3/4inch hole) in the floater. yes it can be done and that would eliminate movement like you said. What I really do not understand is how would the right side of the rear end would shift in the first place with the ladder bars holding it .
Discussion Starter #10
I will do that.
1 - 10 of 10 Posts
