1 - 3 of 3 Posts
Any recommendations on how to cap off the speedometer port on a GF5r? I don't plan to use the speedometer and don't want to cut a perfectly good cable.
Mike
I'm kinda remembering if you leave the nylon gear in the housing, and not attach the cable no oil leaks out. If you got the trans w/o the main shaft gear, cut a piece of sheet metal and epoxy, or great stuff to the case.
I got lucky and found a cap that fits, just added a little silicon.
1 - 3 of 3 Posts
