1 - 7 of 7 Posts
does anyone know what has happened to TAVIA products - they are the recommended suppliers of a pointer to fit the BHJ 6 inch race damper line
I tried everwhere and can't locate any supplier
BHJ said they did not even know that there was a problem as they recommend their pointers also
I want a good pointer to fit - any other ideas of where I can get one
Banned
Tavia is no longer in business.
Thats what I figured - I have been to the web site - dialed the numbers - - no go - thats whay I was asking
so you think the cv products should do the trick then ??
Discussion Starter · #7 ·
Thanks I see CV PRODUCTS have a 6.125" balancer pointer for 283-327 small block and a 6.25" balancer pointer for Fluidampr
should I be concerned about any difference in the mounting position/or in the shape of the actual timing cover/balancer of a 283-327 small block using a 6.125 balancer - since I will be using a std. 350 small block and plan to use a 6 inch damper??
1 - 7 of 7 Posts
