1 - 20 of 32 Posts
anyone with any experiences
i have read some good stuff and some issues about cracking (older castings )
flat top 406 , pump gas , solid flat tappet , .600 lift
little nitrous
they seem like a descent head for the $$$
I have heard the newer castings are better, but if I were buying 23˚ heads it would be Dart for non-CNC heads or AFR's for CNC heads. Darts work very well with little cleanup.
i was considering a pro1 215 platinum as well
they are replacing sportsman II heads , so hopefully either of them will make a difference , the canfields look like they come with better parts
I got the canfields on similar motor ,you wont go wrong. You know CFE uses canfield castings for their CNC heads
Go with the Canfield 215's. They don't need any offset stuff and flow just about as well. Competition Products has the best prices on them I have seen.
the afr heads have a real thick deck which will help with the nitrous,they are a really nice head and have pac springs on them from the factory
Discussion Starter · #8 ·
i have to get rockers anyway , so that isn't an issue
i have a very good price on 220's
kab I have used many Set's of them and they make good power with a little work. For the money there a good head . but the casting is lite and weak in spots . I had to repair 2 this month with broken rocker arm stud pad's. damm round d round guy's they tear up everything .
Discussion Starter · #11 ·
my engine is fairly mild compared to most , its a pump gas street car
with the sportsman II heads i was shifting around 6400 ,weighs 3600 with the steel heads
any idea about how much power i may pick up
i'd like to see .3 improvement in et
I went form the ProTopline 200cc heads on my small block 365 to AFR 210 race ready heads on my new 385. I used the same cam, intake, carb, and the compression also remained the same and I picked up 7 tenths and 6 mph in the 1/8 mile. I give all the credit to the AFR heads.
What does it run now?
Discussion Starter · #14 ·
11.70's @114 has dipped into the .60's once . 7.40's in the 1/8
i would like to see .20's-.30's in the 1/4
i'll probably switch the intake also , right now it has a teamG on it
If you want a big gain, have the Sportsman II heads freshened with new springs for a roller cam and switch to a roller. I ran 8.70's with a 406 and those heads in my old slipjoint dragster. How much converter/stall do you have?
Discussion Starter · #16 ·
the sportsman heads are gone already , a roller is not out of the question , but that would be towards the end of the year
the converter was just something laying around that was thrown in to get the car going
its a 10" cheap pos , flashes 4000-4200 , footbrakes to about 3000 maybe a hair less , i leave off idle , shift at 6400 and go through the traps at around 6200 with a 3.73 gear and 27" radials (255/60)
i have been told the converter is slipping a lot , so i am assuming it is hurting my et aswell , that is next on the list , after i get the engine back together
Discussion Starter · #17 ·
i got the 220 canfields , they are exactly half the weight of the iron heads 27 pounds vs. 54 pounds
i am probably going to try a super victor intake , i know its probably not the best one for this car , but it will be more in line of what i want to do over the winter
any thoughts on if it will make more power than the sportsman heads
still have to buy rockers, wish i had the extra money for shafts but that will have to wait
Bolt em on and let us know. I too am letting go of the Sportman 2s. I went 11.43 @118 with them on a 383 in a Fox. My buddy is putting on a set of Brodix IK 200s for me. Im a little nervous about his choice in head, but he got a screamin deal on them.
yor gonna be glad you didn't get the 215's
If you don't have the money for shaft rockers and need offset intakes we have stud mount rocker sets with 4 left and 4 right offset intakes available in .050", .150" and .250" offset.
1 - 20 of 32 Posts
