1 - 12 of 12 Posts
I am running a N/A 14.1 comp 408 SBF and justed ran some C16 versus the C12. Seemed that the car slowed with the C16. Went 9.92 @ 135 with C12 and slowed to 10.11 @ 133 with C16. Can you guys give me some recomendations on what fuel I should be running and explain if and why too much octane would slow the car? Maybe something else slowed the car. Thank for any help.
Too much octane is no good. Only would I use C16 if I was spraying the car. Stick with the C12. If you call VP Fuels they will tell you to go less than the C16 and maybe suggest C12 or C14
that seems like alot from a octane change. could maybe the air itself changed the power. i know air can make a huge change in power. temp. hum. bar. da
o and my bbc was dyno with c14. c16 on spray but i run c16 on motor and spray. did not know it would hurt performance on motor. good ?
that is EXACTLY what happens when you run a very slow burning forced induction fuel in a N/A car.
Ive been telling my customers this for a long time. If the car ran great on C12 stick with it, otherwise if you are looking to go a little more timing or push the car slightly harder C14 is a great choice as well.
Thanks guys. I have been out of racing for a while so I am learning all this stuff over again. Just put the engine in the car and we are in the process of tuning. I don't race for titles or money, I just do it as a hobby, but I want to make sure that I am using the correct fuel.
Just to add another thought , i know of a former NHRA Stock Eliminator World Champion who won that championship using 118 octane race fuel exclusively . He was matching burn rate to his combo .
Mike Croley
dist. for Competition Race Fuels
i got 2 tenths out of my car,from 9.43 to 924 from lowering the octane i used with no changes to car ,except for fuel used
Discussion Starter · #9 ·
Car seems to be running better with the C12 and the times seem more consistent. Will be using the C12 until I start running the nitrous and then I will switch over to C16. Thanks everyone.
US slow pokes have even experienced this. Example I drove my Old Lightning @ 5 hours to Atco to go racing. We threw the bogarts on, empty'd the tank, threw the Race Tune in it, and C-16'd up. I ran a hi 9 and then it started raining so I had to swap tires and drive it home. My frigging truck didnt even want to start or idle with the dam C-16, plus it ran like shit until I burned it up and got some street fuel back in it...
I find 100 Octane is great for this Cobra but if I ever set it up for Kill and pulley up I'll run C12 or maybe try C16 again ?
on a 2.8kb set on kill go with C16. That blower will like the cooling effects of C16 plus the protection is worth it on a blower setup like that!
As a matter of fact, im trying to get my cousin to swap our his poor ol eaton for that exact blower!
1 - 12 of 12 Posts
