1 - 2 of 2 Posts
re did the converter again, to try and make it looser.
put it all back together with type F fluid and filled it.
seemed to be even slower in spooling up ?
noticed that we had an exhaust leak, pulled both extractors off found massive leakes in the collector pyramids, welded them both up and tried again, was a stinking hot day 105 deg F in the shade ! seemed to be even slower to spool up, however was a bit lean ? will try again soon, but noticed the trans was about 4 litres overfull !
level is good now but need to wait for a calm day when the neighbours and wife are out to try again.
Can an overfull box make the stall speed to weird things ?
1 - 2 of 2 Posts
