1 - 4 of 4 Posts
A friend of mine is building a 565 bbc. The block has been filled up to the water pump. Has anyone here had experience with this......trying to drive a filled block on the street. Is it possible to make it run cool enough.
You're water temp will never know the difference, but what you have to watch now is the oil temp. Oil is what will now be cooling the cylinders instead of water so you'll need a gauge and most likely an oil cooler as well like previously mentioned.
Craig
1 - 4 of 4 Posts
