1 - 20 of 31 Posts
If those numbers are in thousandths (which they should be) the major thrust sides being B and E. That block is plenty thick. with a little core shift.
Min. thickness on the thrust side is about .170 and, min. on the wrist pin side is .140. I have seen them at .125 on the pin side for street use, but for racing I wouldn't want to go that thin.
Don't know the application, but remember, going .200 over only removes .100 of "actual" material.. ;)
So going to 4.540 should be fine for just about anything.
if thats true than we are getting closer...:)
Yeah, it is true, or at least it always has been true, unless something changed.. :rolleyes:
This is all judgmental, I sonic blocks right here, and if I am trying to take a lot out, I check all over trying to find the thin spots, especially if it is a max effort.
Discussion Starter · #19 ·
.314 (thinest area)-.180 (min thickness to achieve) = .134
.134x2=.268 (can safely be removed)
4.340+.268=4.608 overbore...
this is what I have so far, thats my 3rd grade education at work...
What does it cost you to have this done?
Also besides knowing wall thickness is there any other secrets or stuff you guys are looking at?
1 - 20 of 31 Posts
