How would I know? It's a TCI Pro X power glide.Spline count. 17 (powerglide) vs 30 (turbo)
They are not necessarily stronger.... type of material used and the manufacturing process dictates strength. They are popular because you can use a "Turbo" 350/400 torque converter with no other modifications. Be aware, turbo splined powerglide input shafts come in different lengths. Planetary ratio dictates length.
How would you know which input you have? Count the splines, or grab your receipt and call TCI.How would I know? It's a TCI Pro X power glide.
Pretty funnyHow would you know which input you have? Count the splines, or grab your receipt and call TCI.
With the torque converter removed you will see two sets of splines.
The larger diameter is the stator support, the smaller is the input shaft.
All TCI Pro X Power Glides have 30 splines input shafts.How would I know? It's a TCI Pro X power glide.
I'm talking about the different length.Pretty funny![]()
Thanks, so the length doesn't affect the ordering of the converter? Sorry for all the questions, power glides are new to me.pull it out and measure it. Should be 12 7/8 "
No sir just tell em turbo spline, call TSI talk to Justin he can get you up to speed.Thanks, so the length doesn't affect the ordering of the converter? Sorry for all the questions, power glides are new to me.
No, the length has to do with which planetary assembly you have inside the transThanks, so the length doesn't affect the ordering of the converter? Sorry for all the questions, power glides are new to me.
