1 - 8 of 8 Posts
I HAVE A BASICALLY STOCK LQ4 SHORT BLOCK WITH ARP ROD BOLTS, IT HAS L92 HEADS THAT HAVE BEEN SHAVED 0.40. IT HAS A VICTOR JR INTAKE AND A TEXAS SPEED CAM (612 LIFT). DO YOU GUYS THINK IT WOULD LIVE WITH A SMALL CHEAP TURBO SET UP ON IT?
CAPS LOCK BROKEN???
L92s shaved .040? They have a sealing issue with stock deck thickness... Taking .040 off isnt gonna help that.
out of work hair dresser
How much of a sealing issue do they have?
Put 10psi to it and it shouldnt be anywhere near a problem, is that all you're looking at? You said small, small will work, 10psi is pretty small. I have a stock LQ4 with stock 317 heads and it works on 16psi so no reason at least 10psi wouldnt work on your shaved L92 setup. Im near Easton btw.
I'd ditch the cam but the heads should be ok for 10-12 psi of boost with little to no trouble. But your mileage may vary.
my heads were shaved .040 when my L92 was NA. zero sealing issues i ended up trading the shaved heads for unshaved ones to turbo the L92
1 - 8 of 8 Posts
