1 - 8 of 8 Posts
· Registered
A Motorsport block with 55mm cam bearings has a 50mm at the last journal, a Dart block is 55mm at all 5. They make a sleeve for the cam for the last journal to make it 55mm so you can use it in a Dart block after it was made to fit a Motorsport, turn down the inside to fit and grind the OD to fit. I need to know how much press on the ID to keep it on.
· Registered
I have used .0008" to .0012" press fit for cast iron dist drive gears. I would use the same for this. Just make sure when you grind the od on the cam to match the sleeve, it has zero taper. Heat the sleeve with a propane torch and slide it on.
· Registered
Will do, I have heard to freeze the cam too. Does that make any sense?
1 - 8 of 8 Posts
