1 - 18 of 18 Posts
hey guys i got my car all back up and running it runs strong but noises over or falls flat at 6000 rpm heres what i have
565bbc with merlin 320 heads ported and polished pac valves springs 200 seat 475 open. hyd roller camshaft, my question is what rpm range should this camshaft perform in. the car is all motor now but will be twin turbo after i get it sorted out on motor first. im sorry if the picture is large i dont know how to resize it
Long Live The King
565" with .260* dur and a .610 lift cam ... you didn't mention the intake ( Carb, intake manifold)
but with that cam...I'd expect it to fall off at 5,800-6,000
Intake is single plane victor jr. Carb is 1280 davinci carb built for this motor. It does thisi n every gear. Has 36 total timing in it, the car is fast but the engine is lazy and when i brought the cam they said 6500 buti brought it from speed shop instead of having it made myself so i would know for sure if im doing something wrong. To be honest my monte carlo is same setup with diffrent cam. Car weights alot more but it feels alot faster than the camaro i guess thats why this camshaft is not making me happy. Man cams make a big diffrence
what is compression ratio?
i hope you have a short travel lifter. those springs will certainly cause trouble for the lifter if you dont.
Long Live The King
you didn't mention what lifters you were running ?
565
10.8 to 1
RFD Victor Heads
QFT 1050
Stefs Pan
Vacuum Pump
Foxwell Ported Super Victor
Strauby CAm 740/719 270/278 108 Sep
93 BP Gas
916HP @ 7000
765#/ft 5600
Straub posted this in the dyno results sticky. i would stick close to this cam, with less valve lift.
Discussion Starter #12
565
10.8 to 1
RFD Victor Heads
QFT 1050
Stefs Pan
Vacuum Pump
93 BP Gas
916HP @ 7000
765#/ft 5600
Will a cam like that make hp with the turbos and airconditioning. I have been reading and seeing that this camshaft that i have will act totally diffrent when boosted so i will wait and see if not then i will have another made. The part that mainly disappointing me is how lazy the camshaft is
YB Liar and Chief
That cam should work well with boost.
Long Live The King
why ... you don't have the turbos hooked up yet.
Discussion Starter #15
Because it wont be under boost all the time, i have had nitrous motors with nitrous cams ant they still. Were not lazy without the juice. But this is my first time doing turbo stuff so i dont know what it should be like on motor. Fact of the matter is im glad its running and in the morning the turbos will be ordered
sorry, I missed the part about the turbos. must be low compression. and, I can see it being lazy with no boost. its the nature of the beast, I am afraid.
1 - 18 of 18 Posts
