1 - 5 of 5 Posts
I have a friend who bought an used 350 motor. The motor has a mechanical flat tappet crane cam. An old one ss-330-nc is on the cam i cant find any specs online. The cam has worn lobes. We are looking for an replacement its going to be a street/strip motor.
Can anyone suggest a good replacement?
This is what i know about his set up so far
350sbc
4.030
5.7rods
3.50 stroke
3991492 camel backs angle plug 64cc
.200 dome pistons
750 double pumper
th350 trans
professional product hurricane intake
no stall or gear yet. will purchase as needed depending on cam
heads already set up for mechanical flat tappet
thanks for any advise on cam
Re: camshaft advise
I had an old 350 similar to what you have going on. For the cam, I used a Clay Smith Cams grind C-304-8B. It had the following specs: 304/304 adv., 258/258 @ .050, .525/.525" lift w/ 1.5 rockers and a 108 lsa. It was a great little cam and got my shit going 7.40's in the 1/8th in a 3200 lb camaro.
Re: camshaft advise
Also, I ran a summit 10" 3500 stall converter, 4.11 gears in the factory 8.2" with an auburn posi. No transbrake, no nitrous and was my daily driver.
Re: camshaft advise
If your running up to a 3500rpm stall, want good street and strip manners with response and fast times use a 110921 Saturday Night Special lashed at .018"/.018"
280/288 @.020"
244/252 @.050"
152/160 @.200"
.518"/.536"
106 lobe separation
If using say a 4.56 gear and 3000rpm stall, this cam would work great.
If your using 4500rpm stall, go with this cam, 111411, also lashed at .018"/.018"
292/300 @.020"
256/264 @.050"
164/172 @.200"
.545"/.563"
106 lobe separation
seem bout right
1 - 5 of 5 Posts
