I had the biggest solid flat tappet Howards offered at the time. Made 595 HP and 560#. Would run 10.30's at 3200# You might still be able to find it in their catalog. I did also run their direct lube lifters, so got good life out of it. Now that I think of it, the cam is probably still around here.a little help looking for a street track cam for my 408. it's NA 10 1/2 to one 3200 stall 3000 lbs 215 RHS heads
Solid or hydraulic... flat or roller? Rear gear, intended rpm range, amount of street driving, overdrive trans?, Carb, intake...a little help looking for a street track cam for my 408. it's NA 10 1/2 to one 3200 stall 3000 lbs 215 RHS heads
I have this solid roller available if interested. Will need a looser converter. I may have one of those as well.a little help looking for a street track cam for my 408. it's NA 10 1/2 to one 3200 stall 3000 lbs 215 RHS heads
