I have cam here with 16 degrees of duration split and was told i need 14:1+ and/or hit it with at least 450 to really make use of it
well , I'm not a cam guru, but from a purely theoretical standpoint I would think a LOWER compression engine would benefit more than a highCR engine, from greater exhaust duration created by more "split", as it would have a lower expansion ratio on the power stroke, and therfor have more residual pressure in the cylinder.
regarding the nitrous, I can see greater volume of spray needing more exhaust duration as well, simply because there is more exhaust to get out.
The way I see it is you gotta blow the cylinder pressure down enough on the exhaust stroke so that it can make use of the overlap to get the most possible intake charge in.
I'm sure if you posted this question in the Naturally Aspirated section some guys who actually know what they are talking about will chime in, lol
Barrett
