Anyone try this? On my old sb, we used the little wheel piece from Jesel with the embedded magnet but that installed on axis to the cam gear itself. You just had to use a slightly longer LH thread cam bolt for it and you were good to go. My new combo has the fuel pump on axis so I need something radially outward from the center. I'm thinking of just drill a hole in the cam gear, tossing a magnet in there and throwing some epoxy over it. I can build the bracket for it off of the fuel pump bracket because it's pretty sturdy.
Does anyone have any suggestions/tips/hints on the best way to attach the magnet to the cam gear itself? I'll be using the tried and true MSD 2348 for the sensor itself.
If not I will just update this with the gameplan and people can use it for reference (of what not to do).
Here's a pic I found online of a wheel with a magnet stuffed in it but it appears to just be pressed in:
