1 - 5 of 5 Posts
I Tried searching before posting but came up empty handed.
Set up is hydro-roller sbf. Heads were set up with beehives with 155# on the seat.
I'm changing cams and recommended seat pressure is 135-140. Do I need to be concerned with too much pressure?
First cam was a blower cam, new one is NA- same lift.
Thanks in advance.
Thanks in advance.
Is a HYD roller lifter with a .700 wheel which I would not use !!
If your lifter has a .750 wheel which is more of a performance lifter.
Who's lifters are you using ?
Thanks for replies!
I'm using crane link bar lifters. I'll have to research the size of the lifter wheel. What the issue with the smaller wheel?
Its not a performance lifter, If its an enclosed wheel its a .700 wheel
1 - 5 of 5 Posts
