1 - 1 of 1 Posts
My plans have now changed the motor was built with the intent of about a 250 shot. But now i think im going all motor and was wondering how much the current cam is hurting me. What would you guys change in the cam if any? I am shifting at 7600 now but seems to like more just need more runs. 8000 would be max shift point .
fox body mustang 3000lbs. 28x10.5 tire. c6 trans.
4800 stall footbrake 3.73 gear. the gear and convertor will be adjusted as needed.
Spec on motor are:
440 ci yates headed sbf
14.3 to 1
Bore 4.185
stroke 4.0
C3 yates 1.65 jesel
2.10 int titanuim/ 1.60 ext flown on a 4.185 bore
Flow #
int ext
.300= 221 145
.400= 305 192
.500= 359 231
.600= 384 251
.700= 384 263
.800= 382 268 with a pipe
current cam
comp cam hxl lobes
278/288 ls 112.0 icl 111.0 .454 lobe lift.
1 - 1 of 1 Posts
