1 - 5 of 5 Posts
stock 5.3 vic jr msd 6010 3,73 gear turbo 350 3600 stall on a 28 inch tire 1 7/8 header has 650 mechanical carb on it now 150-200kit max looking for an off the shelf cam recommendation. its in a full weight fox body
any help would be great
thanks
You were rolling right along until you said "off the shelf". There is only 1 cam that I know of "off the shelf" that is optimal for your combo. And, lucky for you, it is probably about perfect.
http://www.tickperformance.com/tick-performance-sns-torquemax-stage-2-camshaft-for-ls1-ls6-engines/
You will likely find it will like a 750 Holley HP a little better than that 650 and it will run better with more stall too. But with a 200 shot, you might want to stay around a 4000 RPM 9.5" unit.
yea im looking at a holley 750 hp right now converter is what it is cant afford one right now unfortunately
The Cuban
Brian tooley
1 - 5 of 5 Posts
