That's their intentions, but without actually degreeing it you won't know. Several variables stack up causing the IC to move all over the place. If you just line up the dots, your IC could be anywhere from 4* retarded to 4* advanced. The cam grinder can't predict how precise your timing set and crankshaft are machined.Thanks, another person said it meant that they grind the cam with 5 degrees of advance.
I was wondering if people was just throwing the cams in these turbo junkyard ls builds and running it.That's their intentions, but without actually degreeing it you won't know. Several variables stack up causing the IC to move all over the place. If you just line up the dots, your IC could be anywhere from 4* retarded to 4* advanced. The cam grinder can't predict how precise your timing set and crankshaft are machined.
I bought the hex-a-just chain so that good to hear.thanks for the info.No you would have to buy a degree wheel set or make your own for the LS platform.
I've never installed one cam that came dead nuts as specced, always need some advance/retard to match the cam card. I've always had good luck with Cloyes Hex-a-just timing sets as they allow you to make quick adjustments without taking everything apart.
