1 - 6 of 6 Posts
depends on the rules , engine , application? iv'e done .600" lift " smog legal and smooth idle for the s7 saleens
Thanks, There are no rules its for my kids street car its a 511ci bbc 12:1 comp. a c454 intake and a 1050 dom.not sure about the trans th400 or a 6 speed will this info helps? Thanks Again
is it for the street? is that why u want it to sound tame? 3" to mufflers then 2.5 to tail pipes out the back. no whiz, but small duration will help but crower will fill u in better :) good luck
dual plane manifold required , rpm air gaps are my favorites. , wide lsa 112 adv.2 , mild stick about 244 @ 050" max.. going to bring lift down to reality at .596.". good for valve guide life etc.. on a hi miles streeter. .. kiinda like a marine camshaft thats got to have 11" or more vacum for the efi and shift delay on the drives to shift right at 800 RPm idle speed.
390$ for this cam. rpm range in your 500 "er .. about 2400 to 6200. shift by 6500. good spread of power at low rpms for the 6 spd.
1 - 6 of 6 Posts
