1 - 6 of 6 Posts
hi guys ,heads, are indy 360-1 cnc flow343 @ 650 intake 225 ex @650 ,indy intake,750 bg t d 1.6 rollors. , 410 cube ,11.8 comp ,259/265 @ 050 109 l/c 3 degee advance .200 figures are 176 in 171 ex solid flat tappet, 610 615 lift 1 3/4 pipes 4 into 1, 4500 stall trans brake 904 , 3.9 gears 26/10/15 slicks 3500 lbs. what cam specs do yous think i need and is this grind to small for the combo,will add 150 shot gas later thanks guys
thanks uncle paul it is street strip and most of the time pump fuel flat tappet ,later i might step to a rollor thanks
who is udharold is that harold from ultra dyne
1 - 6 of 6 Posts
