Hey guys...I'm looking at a nitrous cam and was hoping for an opinion or 2 in regards to streetability. I'm not the most knowledgeable when it coma down to these choices and need a little help. This engine will primarily see the strip but I would like to go grab smokes and the occasional jug of milk from time to time! Am I out to lunch here?
Cam Grind Type:Nitrous Roller Cams
Application: FORD 69-93 351W
Block Size: SB
Engine Make: FORD
# Of Cylinders: 8
Manufactured In Year: 69 - 93
Cubic Inch Size / Volume: 351
Additional Qualifier:
Brand Code: Herbert Performance Cams
Cam Only Part #: CJ6F-110LC
Cam Only Price : 229.99
Cam And Lifter Part Number:
Cam And Lifters Price :
Dur Int-Exh: 303/310
Dur @ .050 Int-Exh: 261/270
Lift 1.5 - 1.5 Int/Exh:
Lift 1.6 -1.6 Int/Exh: .672/.668
Lift 1.7 -1.7 Int/Exh:
Lobe Center: 110°
Valve Lash: .025-.025
RPM Range: 4000-7500
Description: Large system, good mid and upper rpm hp. Auto w/race conv. 12.0:1 comp. min.
Cam Options:
Universal Accessories:
Valid Accessory Kits :
Additional Notes:
Block Size: SB
Engine Make: FORD
# Of Cylinders: 8
Lobe Center: 110°
Cam Options:
Additional Notes:
