1 - 5 of 5 Posts
Im detuning my NOS 408,12.5 1,big roller to a
408,11.1 comp and i need a cam to match the compresion and not to slow the car down to much from its best 154mph @3320..
i want to run a solid roller,tight nos converter,4.10s,30 tall drag radial,
23 deegree high ports 256 runner,flow [email protected] lift
bullet cams gave me this recomendation
263-271 @50
661 lift
112 ls
im running a fogger and a plate for nos
thought this one maybe too small to still crack into the 8s
263-271 @50
661 lift
112 ls
BINGO!!
I'd advance that cam maybe 4 to 6 degrees and you will have it
Tom
My 2 cents:
I can't say that's too bad. They may be putting a little focus into making it not be too much of a pig on the mtr. Plus, I have heard that bullit makes great cams, if the profile is aggressive then the .050 numbers do not tell the entire story, the .200 & .300 may be similar to some 280 @ .050 cams. I have no idea, have never used them.
You know I've ran 9.39 @ 144 at 3,520 lbs with a slapper bar car and a big shot plate. My heads flow less than yours (290 @ .700), less compression (only 10.6:1), a few more cubes (434). My cam is 256/264 @ .050 and .624 lift.
So, I can see 8's with what bullit recommended.
Good Luck!
BINGO, before you know it YDLUZ you will be there, stay focused you are on the right track, I like your cam numbers they are in the right direction.
Tom :-D :-D :-D
1 - 5 of 5 Posts
