1 - 2 of 2 Posts
Driver MJM Racing
Hey guys looking for some recomendations or some cam specs that work for you guys with similar combos as to what im looking to try.
496 BBC Dome +43 cc pistons with 320 Int port and 119 Chamber Vol. Brodix Heads around 12.25:1, Single Dominator 1150 Carb on single plane manifold, Race gas 116+, Nitrous motor setup for 350 Shot Plate. 1/8th Mile 2300lb Truck S10 2 speed glide.
Thats roughly the setup looking to do Solid Roller 7500-8000 RPM max.
Driver MJM Racing
Discussion Starter #2
Comp Cams Recomendation:11-750-14 looks good. Good split in duration for the nitrous and a 114 LSA to help on the cylinders. It is also on a 4/7 swap firing order. The specs are duration @ .050 277/292 Lift is .800/.800 with a 114 LSA.
1 - 2 of 2 Posts
