1 - 13 of 13 Posts
Gentlemen
sbc 302
186 heads pocket ported
GM Z intake
11/1
Headers of course
MSD Ignition
QF annular 750
current cam is 30/30. [email protected] 485 lift 114 separation
My Covid shelter at home plan ( Chicago)
12-679-5
252/260 52x 55x
110 separation
Edelbrock TM1 intake
What’s my purpose? Make more power that’s the current cam
gearing is currently Tremec and a 3:73 ( changing to 4:56)
Thoughts ??
Discussion Starter #2
I’d prefer less than 110 like 106. I feel it will be drastic improvement over 114 separation and much less seat duration 😴
Gentlemen
sbc 302
GM Z intake
11/1
Headers of course
MSD Ignition
QF annular 750
12-679-5
252/260 52x 55x
110 separation
Thoughts ??
what do you have for valve springs and rockers ? what is the first gear in the tremec ? tire size ? what rpm do you want to shift at ?106 lsa with 260 would give too late ex valve closing for street use with mufflers imo but would be good with rpm and open headers.
3.27 first gear and 27”
nice , no experience with that trans but lots with muncie in a 69Z and 3.73 should work with that 1st gear maybe 4.56 if Randy gets you launching at 9500 😎 I think that trans has a wide spacing and Od 5th so maybe 4.10 be perfect guess depends how wild you want the cam . if your heads had stock spring pockets and rockers until you upgraded I was thinking 525 lift 108 lsa , isky z35 with 235d springs .
Had a look at the ratios in the tremec and can see why your planing on 4.56 . With that .68 od you could run 4.88 and still have a nice cruise gear for 302 . Big drop 1-2 funny why they used such a low 1st .
just the cam swap will be a definite increase in performance. dont discount the Z intake, as it works quite well for an old dual plane.
For a max of 7,200rpm, this is what I recommend
Cam# SBC, M23352-73359-106
288/292 @.012" (Lash Point)
273/279 @.020"
244/248 @.050"
156/160 @.200"
.352"/.359" Lobe Lift
106 LSA
Lifter# J842MH
.842" Mech F.T. lifter set, w/.024" oiling hole in lifter face
Spring# JRC15
1.250" Single Spring w/Damper
130#@1.750", 347#@1.250", CB 1.150"
cam. .020. .050 .100 .200 .300 lift
30-30 312 254 155 .323
Z-35 288(ad) 254 220 161 90 .350
Jones 273/279 244/248 156/160 .352/.359
Stripes , a circle track cam like CamKings might save you a gear change , or put the 4.56 in with a little more duration and rpm 🤩
1 - 13 of 13 Posts
